é impossivel um E30 de 88 com esse motor... esse so saiu no final de 90 nos E36 e nos E34... em 88 ainda nao havia esse motor...
na minha terra ha um assim, mas foi alterado...
E36 tem versão Is mas so na america...
BMW 325i 1991
- jnm
- O meu Carro:: BMW 523i E39 1999/05
In www.bmwinfo.com
325i M20 6 cylinder 170 HP 220 km/h 1985 - 1991
In www.carfolio.com
Viewing specifications of 1986 BMW 325i
engine
Code
Manufacturer BMW
Type S-6
SOHC
12 valves total
2 valves per cylinder
Main bearings
Construction
Bore × stroke 84.00mm × 75.00mm
3.31 in × 2.95 in
Bore/Stroke ratio 1.12
Displacement 2494 cc
(152.193 cu in)
Unitary capacity 415.67 cc/cylinder
Compression ratio 9.70:1
Fuel system Bo ME-Mot fuel inj.
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter N
Max. output 173.4 PS (171.0 bhp) (127.5 kW)
@5800 rpm
Max. torque 222.0 Nm (164 lbft) (22.6 kgm)
@4000 rpm
Maximum rpm
Coolant Water
Specific output 68.6 bhp/litre
1.12 bhp/cu in
Specific torque 89.01 Nm/litre
In www.autoweb-france.com
BMW E30 325is (1989-1991)
Caractéristiques techniques
Type du moteur : 6 cylindres en ligne
Energie : Essence
Disposition du moteur Longitudinal avant
Alimentation Gestion Bosch Motronic
Suralimentation -
Distribution Arbre à cames en tête
Nombre de soupapes 2 par cylindre
Alésage & Course 84.0 x 75.0 mm
Cylindrée 2494 cc
Compression 9.7
Puissance 171 chevaux à 5800 tr/min
Couple 22.8 mkg à 4000 tr/min
Boite de vitesse 5 rapports
Puissance fiscale 14 chevaux
Penso que estas fontes são fidedignas. Será conveniente não esquecer que em Outubro de 1988 já se estava a produzir o modelo de 1989.
In www.carfolio.com
engine
Code
Manufacturer BMW
Type S-6
SOHC
12 valves total
Main bearings
Construction
3.31 in × 2.95 in
(152.193 cu in)
Aspiration Normal
Compressor type N/A
Intercooler None
@5800 rpm
@4000 rpm
Maximum rpm
Coolant Water
1.12 bhp/cu in
Energie : Essence
Suralimentation -
Cylindrée 2494 cc
Compression 9.7
O prazer de conduzir
